Subpanel Wire Size
RetroActv
Minnesota
I'm working on sizing a subpanel for finishing my basement. Main is 200 amp, and I want to run 100 amp to the subpanel. Distance is about 100 feet, all in-doors.
In looking at wire sizes/ampicities, I believe I can use #1 aluminum, correct? I had thought I needed to use the 60 degree column since I'll be running it through a couple insulated walls, but I understand code changed with the 2017 version in that all SE cable larger than #10 can use 75 degrees.
Am I reading this correctly? I have to call my city to see what version of code they use, but if it is 2017, is my logic sound?
Thanks.
Stuff
Pennsylvania
Logic is sound. Could still go with a 90 amp breaker in the main panel to avoid any arguments. Breaker in sub is optional since in same structure - could still be 100 amp as is considered a disconnect.
Make sure you go with SER 3 wire with ground cable as you need hot-hot-neutral-ground.
