Submersible booster pump in a pressure tank?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Newman, Dec 2, 2018.
  1. Newman
    Newman New Member
    Dec 2, 2018
    CT
    Anybody know if there’s any submersible booster pumps that are made to be used in a water tank that’s pressurized? I came across a product made in the UK, but can’t find anything similarly in the US.
    https://www.scubatank.co.uk/
    The driver would be low noise - I’m looking to install one in our crawlspace that’s right under our living room.
    Thanks.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That is pretty funny! They won't show that it is just a regular submersible well pump. Look for the same thing done in the US using an aerator tank for iron and sulfur. Any storage tank with a submersible pump will do the same thing. Here is a drawing of one using a larger storage tank, but any size tank will work.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Are you sure that tank is pressurized?
    I wonder if a multi-stage booster pump would be quieter than what you have.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    That little tank is square, it cannot be pressurized. There is a little pressure tank on top though.
  6. Newman
    Newman New Member
    Dec 2, 2018
    CT
    Makes more sense that lower tank is not pressurized - it's also available as a two-piece setup where you bolt it together, and can't imagine that's a 80psi world. It sounds like this is to get around flow restrictors they have on the main in the UK, so you have to stockpile your water if you want a large GPM.
    Is something like this doable in the US here? Does it even make any sense? It might be more realistic to just revert to a standard pressurized tank + jet pump and invest in building a sound reducing enclosure.
  7. Reach4
    Sep 25, 2013
    A multi-stage centrifugal pump is like a submersible pump in a housing. I don't know how the sound levels compare to a jet pump.
    In sound isolation, mass helps -- especially for the low frequency components.
    Is the crawl space dirt? If so, you could dig out space, and leave room for sound deadening materials above. A new trap door could make access much easier.
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    Like the drawing I posted, this is done all the time. Jet pump is easier, but makes noise. If you want quite, use a submersible in the storage tank. Here is a pic of a aerator system. But if you want good strong constant pressure use a Cycle Stop Valve like comes in the PK1A kit, which also allows the use of a small pressure tank like in the system you linked. However the system you linked uses an expensive and troublesome Variable Speed Controller or VFD, while the CSV gives the same benefits and a much longer pump life for a fraction of the cost.
  9. Newman
    Newman New Member
    Dec 2, 2018
    CT
    Fantastic help, much appreciated.
    Any sellers/manufactureres that are recommended? Reliability is most important. The Cycle Stop Valves definitely sound like the way to go, I prefer making things simpler if at all possible.
    And the crawlspace is dirt, so it is possible to dig and then cover, although it's not going to be fun.
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    Just Google water storage tanks. There are lots of shapes and sizes. You can even get short ones that will fit in the crawl space. If you get a short tank you can lay a submersible on its side, but use a flow inducer shroud and a cradle to lay the pump in.
  11. valveman
    Mar 15, 2006
    Lubbock, Texas
Similar Threads: Submersible booster
Pumps and Tanks Well Forum & Blog. Water is life. Booster Pump in-line with Submersible Dec 16, 2008
Pumps and Tanks Well Forum & Blog. Water is life. oversized submersible pump Yesterday at 8:47 AM
Pumps and Tanks Well Forum & Blog. Water is life. Submersible lake pump installed. Winter removal? Monday at 1:01 PM
Pumps and Tanks Well Forum & Blog. Water is life. Replaced submersible pump in well now it wont stay on. Apr 17, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Pipe and wire options for submersible pumps Apr 17, 2019
