RonL1
My 220 2 wire submersible normally runs for roughly 4 minutes while it's pushing water through my geothermal heat pump. And draws about 1280 watts (5.25 amps) I monitor them using an emporia monitor. I just happen to see my well kick on at half the watts (547) for 16 minutes ( and there was no variation 547 solid) . Then turn off and then 2minutes later kick on at normal draw for its 4 minute cycle. And this was in the middle of a long heat pump cycle.where it ran normal before and after all during the heat pump cycle.. it's like it started sucking air and needed less watts to run, but if that happened the heat pump would have quit. And it didnt So the pump must have been pushing some water. Any ideas ? It's been running normal since ... even through an hour long heat pump cycle.
