ncgeo
I'm trying to remove my submersible pump from a partially-uncased well but not having much luck. I was able to raise it about 3 feet with some strong backs, but no further and it won't drop back down. Also the pipe/pump won't turn in the bore hole so is probably not the torque arrestor hanging up; its more likely the pump hung up in a collapse. It's hanging on 100' of poly so it cannot be pushed down. I haven't called in anyone with a pulling rig, yet.
I know this topic has been discussed often through the years, and it seems the typical answer is to pull and pray the pipe breaks near the pump. Has anyone tried using a drilling rig with a bit or some steel pipe to push it down? Can the pump be drilled out? Is there any type of small, brushcutting type saw that could be lowered into the well to sever the pipe just above the pump? If not, someone should build one. There seems to be a good number of people who have this issue.
I did speak to one local driller who proposed bringing in a small rig and pushing on the pump with pipe in an attempt to loosen or send to the bottom of the well, but I would still be faced with hoping the pipe broke in the right place. Worst case say the pipe breaks near the top of the well ... is it possible to send down new 4" pump in the 6" well alongside the 1" poly? The problem I see with that is the cableguards; no sure they can be pushed out of the way with the new pump.
Looking for any and all ideas. I'm ready to get a pro involved but looking for some more certainty than a prayer.
