Stuck closet auger
Discussion in 'Toilet Forum discussions' started by Rich Hanna, May 23, 2020 at 3:25 PM.
  1. Rich Hanna
    Rich Hanna New Member
    Saturday
    Maryland
    Background - I'm clearly not a professional.
    My wife flushed cucumber pieces down the toilet. Not great results. I tried my closet auger (the shorter kind), but did not clear the clog even though the auger was fully extended. When trying to retrieve the auger, the head got stuck pretty tight somewhere. I tried pulling it out pretty hard, but not as hard as I possibly can.
    I pulled the toilet out (augur still attached). Found a good chunk of cucumber at the toilet outlet and cleared that. Auger is still stuck.
    Two theories:
    1) The auger head is just stuck in the toilet bend and if I pull hard enough it will come out. How likely is this?
    2) The auger head is stuck in a cucumber piece, which is itself stuck. Intel from my wife suggests there is one piece of cucumber unaccounted for.
    If option 1 is correct, my best option is to monkey with the auger and pull on it until it comes out.
    If option 2 is correct, my best option is drain the toilet completely and wait a bit until the cucumber dries up and shrinks.
    Any advice?
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I would rotate the closet auger CCW.
    I can't imagine a way the problem is getting stuck in a cucumber.
  4. James Henry
    James Henry In the Trades
    Jul 23, 2019
    Billings, Montana.
    Sounds like it got tangled. try to push it through the toilet, if you can see the end of it grab it with some pliers, if that doesn't work I would give it a couple good jerks. I cant imagine it tied it self into a knot but anythings possible.
  5. Reach4
    Sep 25, 2013
    At first I thought you were saying that the tip of the auger was below floor level. Is the tip actually above floor level inside of the toilet? If so, and you have to put in a new toilet, it will probably be a better flusher anyway.
  6. Rich Hanna
    Saturday
    Maryland
    Thanks for the comments.
    Its not below floor level. If I push the auger in as far as it will go, I cannot see the tip at the exit.
    I'm guessing that means its tangled.
  7. Reach4
    Sep 25, 2013
    The fact that you had an auger at the ready might indicate that a new toilet may be a good thing. So yank. If the toilet breaks, it breaks.
Similar Threads: Stuck closet
Toilet Forum discussions Need a guaranteed to stop stuck flapper issue Sep 17, 2018
Toilet Forum discussions Need assistance with stuck fill valve on polybutylene piping - possible solutions? Dec 7, 2016
Toilet Forum discussions Toto flush lever getting stuck. Aug 12, 2014
Toilet Forum discussions Want to change wax ring, but toilet is stuck fast like a vacuum seal. Feb 2, 2012
Toilet Forum discussions Weak flush...something stuck? Feb 17, 2011
