hoodun
First off I am a rookie DIY plumber.
Has anyone ever used structural plywood to support holes drilled in studs?
I have a king stud I drilled a hole into that is 63%. Initially was planning on using a 3" nominal shoe for it since it is actual 2". Its a 100 year old stud. Though not sure how inspector will like it. Even though it is single story and there are 1" x 8" plank attached from the outside along with cross beams, this is California...
My plan was to put a structural piece of plywood across three studs down to the bottom and up to the angle brace. Then put screws staggered every 3" like a box header. Seem like it would be much stronger than it was and fix the issue of having drilled into the king stud.
Any thoughts?
Any thoughts?
