Stress Cracks In Garden Apt Bathtub
NDL
Charlotte, NC
I am a big (and tall) guy, whose never had a problem with a metal tub; steel, cast iron, etc
My current garden apartment rental - of 3 weeks - built in the mid 1980's, has a plastic bathtub. Tonight I noticed several small stress cracks developing (3), and I am beside myself.
*If* and *when* you get in and out of the tub, or shift your position in the tub, the bottom creaks; it's mostly sturdy, but there's a minimal amount of flex, and the flex (creak) is audible. The bottom doesn't shift around much, but it does shift/creak in two places.
As luck would have it, it looks as though there are very fine cracks starting. It was bound to happen because the bottom of the tub shifts, and the tub unit is old.
***There's nothing to take a picture of; the cracks are so fine as to be unseen in pictures,*** but close examination and scrutiny will show that they're starting.
I suppose that, over time, these cracks will spread, causing a leak? I also suppose that I will be responsible for footing the bill for the whole damned thing.
Many of the units in this complex have metal tubs; as luck would have it, I have a model with a plastic tub.
I am sorry for rambling; we just moved into the unit three weeks ago; the cracks didn't appear before. I suppose that this is like playing a game of hot potato: you've got an old plastic tub, whose base is mostly supported, yet it creaks in two spots; over time I suppose it will crack, and whoever winds up with the cracked base gets to pay for it.
Any thoughts? Again, there's nothing to take a picture of (yet). Thanks in advance
ImOld
Octogenerian
In the rumble seat
Putting aside your thoughts on the tub, owners not renters are responsible for repairs unless your lease says otherwise. I'll let the members who have experience with plastic tubs, I don't, comment on the tub.
Dj2
California
Alert the manager/owner.
Without seeing it: It could be what's under the tub, or what's missing under the tub.
  • Like
Reactions: NDL
Some stress cracks have been there a while. You're looking at the coating over the fiberglass which can be repaired and refinished. Good support does go a long way in preventing movement though.
  • Like
Reactions: NDL
NDL
Charlotte, NC
Thank you both, for your replies. I did just what you suggested:
That is exactly what the maintenance team said. Many thanks for the education; I thought the sight of a stress crack was the death knell of the tub.
It turns out that the cracks are surface only, and action is only necessary if they get worse. Worst case scenario, it needs to be refinished. Thankfully, the entire thing doesn't need to be gutted.
Again...thank you!
