fernf5
Searching the internet for help because of my lack of knowledge I stumbled upon this site. Seems like the knowledge needed is certainly here.
There is a long backstory here but I'll try to keep this short.
I installed an irrigation system and 500 gal. holding tank that is
fed from my 5 GPM well. The holding tank is enough to water what we need (backyard) but
it only refills when the house holding tank empties during normal use. This
leads to being out of water for 1 1/2 to 2 hours at random times while the 500 gal tank
refills. We have a pump control switch installed to start the pump in the
500 gal tank. I am hoping there is a way to install a float type switch in
the 500 gal tank and have it start the well pumping water when the level
goes down. Then we could irrigate at night and not be without water for long
periods. There is a float valve in the tank which shuts off water when it is
full.
What I need to know is what equipment I need to install be able to control when the well fills the 500 gal. holding tank. I'm a complete rookie at this. That's why I didn't get it right when I initially installed everything and am trying to retro fix it.I've read a lot of posts here but haven't been able to get an exact answer.
I attached a "line" drawing to hopefully make things clearer.
full.
