Spiderman2018
Hi All.
I just have a unit installed. Do I really need to have a discharge pipe installed?
The tank is filled with water and air has been purged. The TP relief valve is installed. If pressure gets too high I assume I would see leak from the valve. It’s at a small business and flooring is tile so a small amount of water on the floor is not a problem and the unit would be turned off when we’re not there.
I’ve been told that these units are sometimes installed under sink and most frequently a discharged pipe is not used.
Also the instructions say to relieve the valve once a month but at the risk of messing up the valve. So is that necessary?
Stiebel Eltron 235089 SHC 6 Mini-Tank Electric Water Heater, 6 Gallon, 1300W, 120V, 15-1/8" W x 20-1/2" H x 15" D
