So I'm intrigued with the concept. I've read all of the threads I could find, and watched a few YT videos on the subject.
I understand the principle, but am curious about using it for a long-term maintenance-free application. And, since I'm a bit of a gadget geek, I was considering installing a pressure transducer so I could continuously and remotely monitor the readings (with the added benefit of receiving an alert/text message when the level falls below a critical level).
My well is 270' deep.
Pump is at approximately 250'.
Static level is currently at 44' below ground.
Recovery is a paltry 2.5GPM <--- and this is why the level is important to me. With 40+ min of water use, my well will run dry.
The plan would be to install a 250' line of 1/2" PEX-AL and capping it with a pressure gauge/transducer - flushing the line with air.
The question is, will that reading be dynamic and accurately trend with the in/decrease of water above the end of the airline? Since decreasing water level would mean decreasing pressure, I can only assume if the water level drops low enough, the air pressure will ultimately force air out of the bottom of the line (even if the water level is physically still above the end of the tube) and thereby screwing up any additional readings.
This is where I'm a bit fuzzy... If I have a known (tape-measured) static level, could I not just partially fill the tube (i.e. not expel ALL of the water), thereby allowing a margin so that if the water level drops to critically low levels, there's still enough of a water column in the tube to prevent it from completely purging? I'd have to correct for the pressure delta, but the linear 2.3' per PSI would still apply, no?
TL/DR: Ultimately, I'm after a way have a real-time, remotely-accessible way to verify the water level using the air line method, and just need to verify that I don't need to add air at any point after the initial charge.
