Jared Kendrick
I have a State tankless propane water heater model # GAX 199P. It was made around 2007 and I was told it was before State made their own heaters but don't know the manufacturer, though I know it's Japanese. Water heater worked fine since we bought the house 6 months ago though it seemed it would occasionally surge temperature down a little while taking a shower. The other day it just quit. With hot running in house it does nothing. No blower, no flame nothing. I know it is getting power to the control board because when I unplugged a line the red light came on. I took the filter out of the incoming line and it was clear. We have soft water and we don't have much problem with scale or corrosion with our water. It is making just a little heat but it seems to be from an electrical heater (maybe anti-freeze) in heat exchanger. I called State's tech line and was told it might be the flow sensor coming into the unit since the blower motor isn't even running but they weren't sure. Any suggestions or anything pointing me in a direction would be greatly appreciated. I cannot afford another water heater now and I think I can fix this one if I can figure out what's going on. Thank you so much for the help!
