Scott Amendolaro
My Sprinkler pump recently started intermittently tripping breakers on startup. When it does start pump runs it is working fine .
I have noticed that the pump is buzzing pretty loud for sometime 5-10 seconds before the breaker trips. I looked at my TED monitor while this happened and it looks like the pump was drawing 10kw for 13+ seconds (@ 240) before the trip. When I reset and restart that delay is often about 4-5 seconds before it starts. So it definitely looks like the amp pull is causing it.
Not sure at this point if its the motor or the Cap and thought I would ask here what you thought before I went and bought a new motor.
The DS3HF is about 7 years old , running on an artisan well .
Thanks
Scott
(Below is a look at the Sprinkler pump turning on and when the breaker trips. Each dot is a second
Thanks
Scott
