Sprinkler Up and Running One Day, Zero Pressure Next
Pcapes
Minnesota
HI,
I have a sandpoint/sprinkler system. We have been trying to get it up and running. Have not had luck with heads coming up. Ended up attaching a hose (with good water pressure) to the pipe coming out of the pump. (give it a jumpstart so all the lines had water)
Did a test run of all the zones. All popped up and worked. Shut system off, started back up and ran 10 zones for 35 min a zone. Had great pressure, 30-40 psi. every zone. Everything worked as normal.
Then system was set to restart this morning, came on, and ran but 0 pressure. No heads coming up.
Any thoughts?
