Theeokie
I am helping some friends increase their storage on a farm fed by a spring system, they recently added 400' of high tunnels with a mister setup and need make sure they have adequate storage/pressure for drip irrigation and their other utility needs.
Currently they have a gravity fed system to a 800 gal tank that has maybe 20' of drop from the tank to the bulk of the system. Ideally we would add a 2500 gal storage tank down stream of the 800 gal tank that is already in place. What sort of pressure system would be best? I have not measured the delivery of the spring but it varies wildly since it gets quite a bit of surface run off in the winter months. This water system also feeds one household's domestic needs.
On a side note the 800 gal tank is somewhere not reachable for AC power and it would be handy to have a float switch with some sort of alarm to notify us when that tank has been drawn down to 50% or so beacause the spring line has been disrupted somehow; bear bite, shift in the spring, failed fitting or pipe etc etc
Thank you for advice and help!
