Sprayer replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dr_1400, Mar 30, 2020.
  1. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    I am replacing a leaking sprayer head on kitchen sink. The replacement nut will not fit over the sprayer hose. Is one of the following correct?
    1) Replacement sprayers must be sized correctly (no universal hose diameter)
    2) I need to upgrade my old hose to accept a new sprayer head?
    top pic shows nut that won’t fit over hose
    Bottom pic shows old nut that slides right into place
    4AC04678-DC11-4066-A819-B2BD2D0D3438.jpeg 8A5BCC04-1178-4831-BFE9-560C95B19C20.jpeg
  2. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    Bumping this, anyone have ideas? Leaking sprayer driving me nuts!
  4. James Henry
    James Henry In the Trades
    Jul 23, 2019
    Billings, Montana.
  5. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
  6. James Henry
    Jul 23, 2019
    Billings, Montana.
    you need to disconnect the sprayer hose from the faucet, write down the make and model # of the faucet and take it to the hardware store and try to match, it its that simple. The new sprayer and hose will list on the package which faucet it will work with. if they don't have it you can easily order it on line. also the faucet may have a lifetime warranty and you might be able to get the replacement part for free. look it up. theirs 6 different ways to tackle this but you need to start with finding out the make and model # of the faucet then you can call around.
  7. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    Thank you, I appreciate the help.
  8. Terry
    Aug 17, 2004
    Don't forget the clip that holds the spray handle on the hose.
    [​IMG]
  9. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    I took the clip off and got to the point shown in this picture, but the replacement nut (“A” in the graphic you posted) won’t slide past the end of the hose. Am I missing something there?
  10. Terry
    Aug 17, 2004
    Did you also remove the nylon washer?
    D
    [​IMG]
  11. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    I did not remove the part I’ve pointed to in this image. I didn’t think I should because the old nut slides right over that, as well.
  12. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    Connection underneath is this. Would like to replace the whole hose and sprayer at this point, but we’re an hr from a hardware store and not sure what to make of the connection. Quick connect?
  13. Terry
    Aug 17, 2004
    Is that a tag on the supply line to the faucet? You might have to connect the manufacuer for a replacement.
  14. Dr_1400
    Dr_1400 New Member
    Mar 30, 2020
    NY
    I am not sure. This is at a remote off grid cabin, I’m not there now. Will check that out next time I am there.
  15. fullysprinklered
    fullysprinklered In the Trades
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    Reach up under there and squeeze that black thing where the hose meets the faucet. It's a quick connect and is brand specific. Squeeze it and push up some, then pull it down. Should disconnect.
Similar Threads: Sprayer replacement
Plumbing Forum, Professional & DIY Advice Aquasource sprayer hose replacement Jul 4, 2018
Plumbing Forum, Professional & DIY Advice Kitchen sprayer guide replacement Aug 7, 2013
Plumbing Forum, Professional & DIY Advice Garden Hose Sprayer to Shower Hose Question Dec 28, 2020
Plumbing Forum, Professional & DIY Advice How to shorten hose on Moen 7165 side sink sprayer Dec 7, 2020
Plumbing Forum, Professional & DIY Advice RESOLVED Dilemma - sprayer-leak risk vs. swivel-spray pot-clearance risk Oct 27, 2020
