elgato
Concrete floor, 4” ABS with rusted steel flange.
ISSUES:
1. Top of flange is about 3/16” below tile.
2. Flange is rusted bad enough that it will not hold bolts much longer.
3. Concrete is not poured up to ABS. Nothing to screw into.
4. Rear tile is about 1/8” higher than front tile. Not sure why.
INITIAL OPTIONS:
My plumber suggested a replacement flange that twists into the 4”. This would
need to be anchored with screws into concrete, correct?
Possibly use the Moss Bay flange?
This is from another thread.
“if you want to get yourself into tons of
trouble go ahead and cut that ring off that
plastic flange embedded in concrete.....”
It also does not solve the height issue and need to be anchored.
How can you be certain that it will fit?
Use a repair plate and just screw it into the existing flange?
Recommendations Please.
Also,
When shimming, do you place the shims under the ribs running across the toilet or under
The edges?
Thanks again for the help.
ISSUES:
INITIAL OPTIONS:
Also,
The edges?
