mayanees
I'm getting water in my basement and it appears to be seeping through the wall, with the apparent source being the pressurized well black poly pipe. I have a submersible pump outside that feeds the black poly that runs 40 feet to the corner of the basement and enters through the wall as shown on the attached picture. It's been there since the house was built 40 years ago. It will be difficult to dig down to it from the outside because it goes under a brick patio and poured step. Along with the black poly pipe is a ground wire that runs to the electrical panel.
Is the black poly pipe subject to breaking down over time? I thought that stuff was nearly indestructible.
I'm going to contact a plumber because I think it might be wise to disconnect the pipe at the wall and stick a pipe probe/camera down the pipe to inspect for a break. The other alternative is to dig down from the outside, but that could be destructive to the brick steps since the pipe goes under that assembly.
Suggestions for a pathforward or any insight are welcomed and appreciated.
