Betsy Callahan
Master bath shower in home built in 1989 has 4 1/4" x 4 1/4" white, shiny tile on 2 walls with glass enclosure making the other 2 walls of enclosed shower. I noticed some grout was failing and if I gently push on some areas of the tile, those areas bend inwards, and in other areas it does not bend at all. Does this sound like a problem with the wall that the tile is cemented onto or would loose, old grout cause this to happen? I was going to clean out the grout and re grout the tile, but if there is a problem behind the tile with the wall itself, I need to fix that right? I haven't taken a shower in that shower since I noticed this, because I don't want water to get through the grout and back into the wall. Any insights as to what may be happening and what to do are greatly appreciated. Thank you.
