tobinator
Just finished making some major changes to my drain and septic systems and I've created a problem with sewer gas. Can I get some advice on fixing?
I rerouted my main 3" drain pipe to exit from a different point in my house, closer to my new septic tank. Used to have a pretty gentle slope and exit my house through the floor slab in my finished bsmt. I rerouted the run to exit though the stem wall in my laundry room so I didn't have to build out a chase to cover the drain pipes. After the pipe exits the bsmt., it drops pretty sharply to the level of the septic tank inlet. Drop is about 3' in 15' run. Final drain pipe is 3" ABS.
I'm getting gas through the vent/drain of my main floor shower, the last drain connection before the aformentioned changes. I'm pretty sure that the increased drop is siphoning the water from my tub trap.
Switching back to the old drain exit point is not an option. Short of that, would a deeper or bigger trap help (currently trap is 1 1/2' ABS that's only about 1" deeper than the depth of the 'P'). Could I "couple in" some depth to the trap to add a couple inches of water? Or could I switch to a 2" trap? What about an AAV? If they come in 3" ABS that might make it easy, otherwise I might be able to make a 1 1/2" or 2" AAV work?
Thanks,
Matt
Thanks,
Matt
