WorthFlorida
An air handler mounted humidifier would be attached to the side of the duct work above the furnace and probably the AC coil. If you have one inside the duct work you'll need to open it up and check the condition.
Check the float valve in the humidifier. The valve you replaced turns the water on and off to the humidifier but the humidifier has a tray or tank with a float valve that works similar to a toilet tank. This area will get all gummed up with mineral deposits as the water is evaporated. Some units will have a wheel with mesh like fabric that rotates or a pad in and above the water to allow water to be absorbed into the pad for vaporization. You can clean it with vinegar. Humidifiers take a lot of maintenance depending on how hard your water is. It should opened and checked at least once a month during the heating season and in the off season completely removed and cleaned. Just remember you are breathing mold that will grow in humidifiers.
