Soldering next to a threaded fitting on a three way shower diverter
Discussion in 'Shower & Bathtub Forum & Blog' started by Trevor Persson, Dec 30, 2017.
  1. Trevor Persson
    Trevor Persson New Member
    Dec 30, 2017
    Calgary
    I have five lines coming in and out of a new shower diverter. I did all the copper soldering of elbows and such prior to fitting the lines to the diverter, so that I wouldn't heat up the unit. I applied plumbers tape to the threads, supplied by the manufacturer (Pearl), about 2-3 wraps, then I used a wrench to install the fitting with the pre-soldered pipes. Final solder joints were done about 12-20" from the unit for each line. After all that the hot & cold threaded fittings have a very slow leak, so now I have to fix it while it's installed.
    I only have about 3-4" of copper from the threaded fitting to the first elbow, so I can cut out that section and re-solder it, but I can't figure out why I have a leak and I'm concerned that when I solder that close to the fitting it will damage the tape and create a leak. I believe it's a brass diverter, I used a copper connector to a 1/2" pipe. I've done lots of copper soldering and that part is threaded fitting is new to me.
    Should I use "PFTE Thread Compound" or does anyone have a better idea?
  2. Terry
    Aug 17, 2004
    Anytime you thread in a male adapter to the body of the shower valve, it needs to be pretty tight. Tape and then some thread sealant over that helps to seal. Either tape, or sealant should work, but sometimes both being used is even better.
    MASTERPLUMB777 likes this.
  4. Trevor Persson
    Dec 30, 2017
    Calgary
    Thanks Terry. I was pretty aggressive with the wrench, but I'll add some sealant this next time.
  5. Trevor Persson
    Dec 30, 2017
    Calgary
    I went back to Rona to get supplies and asked there as well, he asked about the tape I used. When he heard what it was, he immediately showed me some proper tape and was very critical of any tape provided with the diverter. The tape was pink and much thicker that most.
    I also used sealant with the tape and everything worked out great this go around. Thanks Terry.
  6. David Yates
    David Yates New Member
    Oct 30, 2014
    IT Professional
    Calgary, Alberta
    Amazing - we know each other!
Similar Threads: Soldering next
Shower & Bathtub Forum & Blog Soldering on the grill - really. Jul 17, 2015
Shower & Bathtub Forum & Blog Delta R10000 installation...leave plastic screen in during soldering?? Aug 14, 2013
Shower & Bathtub Forum & Blog Did I overheat the valve when soldering? Aug 25, 2009
Shower & Bathtub Forum & Blog Moentrol 3330 - pulling cart prior to soldering?! Nov 20, 2007
Shower & Bathtub Forum & Blog Soldering question for new shower faucet May 21, 2006
