Lithnights
I just soldered a 1 1/2" copper pipe to a brass fitting. I heated the fitting for a good while (longer than my typical 1/2" copper sweats) then soldered and the solder took pretty nicely all the way around.
My only issue is that I was soldering from an angle where I couldn't see the bottom of the pipe. I got down as low as I could and definitely saw the solder taking. This is the drain for my soon to be installed bathtub. See attached picture.
Is there a standard way to test this joint to make sure I don't have any leaks? I assume I could set up some contraption or dry fit my overflow assembly and run hose water through it to see if there are any pinsize leaks...?
Any other ideas? I want to make sure it's a solid fit before installing my tub and then tile over the tub. Once that's in, I'd be stuck if it had any leaks. I guess I could always get to it from below if needed but that would require ripping a hole in my 1st floor ceiling.
Thanks in advance,
Thanks in advance,
