firelikeiya
Hey guys,
Definite newbie here to soldering. I just soldered a bypass loop for a water softener. I deburred the inside and outside of all the pipes, cleaned with a tube cleaning brush, and applied flux to the copper pipe and the fitting. I used MAPP gas. I sweated 1" copper pipe and used just over 1" of solder per joint. My problem is that all of the solder seems to have sucked in on my fittings. Instead of having that nice bead that professionals get, I have a slightly sucked in ridge all around. I did this late last night and the lighting was bad. I put water to the system last night and everything held. I wired brushed all of the joints this morning and there is complete solder all the way around every joint. I have a strong feeling most of the solder got sucked into the pipes. Is there anything I should do or be worried about? Should I redo the joints? Thanks for any help.
