Supr
hi, new here and first time actually replacing my softener.
first of all, I'm so glad i found this site. its by FAR the most informative i have found. and not having pushy salespeople is a big plus.
so, i currently have a GE GNPR40L00 which i cant really seem to find any info for. I've had it for almost exactly 10 years now and its throwing a Error 3 which has to do with the timer. i had the person who originally installed it come out and take a look and he said that its pretty much reached the end of its life and would be 3-6k to replace. now 10 years is what ive been reading but 3-6k?????
I've done tons of researching and looks like you can get a great quality setup for $6-900 and this is definitely something i can install myself. specifically looking at the Fleck 5600sxt, that's what everyone seems to recommend.
any tips for a noob? i also read about a couple other brands, which don't come to mind but this one seems to be everyone's favorite.
I'm starting at the beginning by testing my water. after that i need to somehow figure out how much water we use. no meter here since were on a well so any help in this area would be great. from my calculations so far i would need a unit that does around 40,000gr.
the unit i have now says its rated at 4,720 grains @ 3lbs, I'm not sure what to make of that.
i also have a question about the drain. i know its best to have it go to a floor drain but the way its setup now is that i have a restroom in the corner of my garage and this is on the other side of my restroom wall. the drain goes into the restroom sink drain i know it works because you can hear it drain but after it leaves the softener and before it enters the wall there is a 6" rise. not sure why he did it this way because it was the same plumber who plumbed our house that installed this system. is this 6" rise a problem? would the new unit pump the brine out and into the drain?
sorry for the long read. any help would be great.
thanks
thanks
