gargodude
This is my first post here. Seems like there is more real knowledge here than on most of the equipment sales websites I have visited, so I thought it would be a good idea to sign up.
We live in Northern CA in the Sierra foothills, are on well water and it's just my wife and I in a 2 bathroom house. I would say that our water use is a bit above normal since my wife likes to take 10 minute showers with our 4GPM head and we seem to do about 7 loads of laundry per week. I installed a calcite neutralizer and a softener 10-1/2 years ago because when I bough the house 13 years ago, I had noticed blue stains under the fixtures from the acid water eating at the copper pipes and didn't want to end up replacing the plumbing like my neighbor had. There were also gray streaks on the sides of the toilet bowls which have since been controlled by the softener. The only adjustments I have made to the system were upon advice from the place where I bought it. That was changing the salt setting gradually higher from 12 to 18.
I recently went through the units because they were losing their effectiveness. My neutralizer was losing its effectiveness from channeling and freshly added media was being drawn out into the plumbing during backwash so I replaced it with a 2.5 cu ft. upflow unit with a non-backwashing Clack head. The water in the house is now at pH 7.0. I also re-bedded my softener which is a 1.5 cu ft. unit with an Autotrol 268 head and a 460i control. I had originally ordered a 1.0 cu ft. softener (10 years ago) upon the advice of CAI Technologies (now out of business) but they sent me a 1.5 cu. ft. unit by mistake. They said I could just keep it and use it without issues so I did. I realize that it's too big for just me and my wife, but that's what I have so I want to make it work if I can.
When I had my water tested (2 different places, 10 years ago), it measured between 4 and 5 grains of hardness, no iron and had a pH of 6.6. I have a nice electronic pH meter that still shows the pH at 6.6 (before the system) and I assume the hardness is about the same. I've read that my neutralizer adds about 5-6 grains of hardness so I set the softener hardness at 11 (5+6), the capacity at 38 (recommended by CAI when I bought it) and the salt dial at 13. The brine tank was cleaned out and seems to be working properly.
I am concerned that I will experience what I have for the last 10 years which is a really long period between regenerations, followed by really soft, slippery feeling water which fades away over the next few weeks and returns upon the next regen cycle which are about 3 weeks apart. I have been reading a few articles about "efficient salt usage" which suggest setting the salt dial lower and having the softener regenerate more often which will use less salt over time (while using more water) and reducing the regen period to about 7 days which is supposed to be optimum. It would seem to me that the softener would not regen more often by simply adjusting the salt dial. You would have to fool it into more frequent regeneration by increasing the hardness or reducing the capacity setting, right?
For all you pros out there: If you had this situation how would you set this up?
