ml1337
Hello, I would like to ask your kind help in picking a proper softener for my family of 3 (soon to be 4). I'm going to try to keep this as factual as possible:
- Occupants: 2 adults and 2 small kids
- Bathrooms: 3.5
- Average Water Usage: 2,000 to 3,000 gallons
- City water
- Hardness: 7
- Iron: 0
- PH: 7.4
- TDS: 153
- Total Chlorine: 0
- Free Chlorine: > 0.1
- Supply: 1'' copper
- Drain: 4'' PVC
- Installation Location: Unfinished basement (no plan to finish). See attached pic for planned location. It's right next to the entry point of the supply pipe and the exit point of the waste pipe.
I'm leaning towards a 48K fleck 5600SXT single tank unit, but I have read some good stuff about the 9100SXT twin tank unit (namely that it's more water and salt efficient?). It looks like the 48K would give me 68 days before a regeneration is needed (!).
- Is there a disadvantage to spacing out the regeneration so much? I have learned recently that they should be forced after 14 days? Why is that?
- If the above is true, should I go with a much smaller unit such as the 32K or even less? seems like I would use more salt and water if I went that route.
- I don't care about 24/7 soft water, but it appears like the twin tank units are also more efficient on water/salt use?
Thank you!
- Bathrooms: 3.5
- City water
- Hardness: 7
- Iron: 0
- PH: 7.4
- TDS: 153
- Total Chlorine: 0
- Drain: 4'' PVC
Thank you!
