Softener issues & questions
Yes. I expect your backwash water would be about 59 degrees, and I would go 9 gpm, or maybe 10.
If your tank is natural tan (unpainted), you can shine a bright light thru in the dark, and see the shadow of the media. It should rise during backwash.
JustaDIYer
Novi, Michigan
looks like my set up can only take up to a 7gpm button. it has the 3/4" drain line connector.
To go up to 9gpm, I'd need a new drain line connector, 1".
My drain line is 3/4" pvc which I'm sure is plenty if I upgrade, just need a reducer after the exit.
