JustaDIYer
FM = T0.7
Seems my usable gallons went up from 1000 (old valve) to 1800.
Steel (galvanized) pipes after your treatment?What else would cause rust color stains?
Nope. Either copper or PEXSteel (galvanized) pipes after your treatment?
Is the iron filter control valve (brand and model?) programmed as a filter or as a softener?how do i get it into the tank using the BD ?
Is your softener actually equipped with a Turbine Flow Meter or a Paddlewheel Flow Meter? It seems your old valve may have been programmed as FM=P.07, so unless you also replaced the flow meter when you replaced the control valve, the correct setting may continue to be P.07. Post a photo of the current flow meter to verify the correct setting.FM = T0.7
Probably don't have an injector. It's Fleck 5810 SXT. Has the softener valve set up.Is the iron filter control valve (brand and model?) programmed as a filter or as a softener?
For brine, chlorine or air to be drawn in through the brine tube, an injector would need to be installed. Backwashing Filters normally only utilize a Backwash and Rapid Rinse cycle and so do not typically utilize an injector or brine control assembly. If an injector is installed, what color/number is it?
Turbine flow meter. All new valve head. Left the bypass is all.Is your softener actually equipped with a Turbine Flow Meter or a Paddlewheel Flow Meter? It seems your old valve may have been programmed as FM=P.07, so unless you also replaced the flow meter when you replaced the control valve, the correct setting may continue to be P.07. Post a photo of the current flow meter to verify the correct setting.
If the flow meter setting for each softener control valve had been appropriate for the actual flow meter type, and if identical Capacity, Hardness and Reserve settings had been programmed in each, then the post regeneration usable gallons should have been identical or at least close within reason.Seems my usable gallons went up from 1000 (old valve) to 1800.
Hence my confusion. I copied the settings from the old valve to the new one.If the flow meter setting for each softener control valve had been appropriate for the actual flow meter type, and if identical Capacity, Hardness and Reserve settings had been programmed in each, then the post regeneration usable gallons should have been identical or at least close within reason.
Was the old valve also utilizing a turbine flow meter but programmed for a paddlewheel meter?
Katalox Light media is designed to 1st oxidize ferrous iron, and then filter out the resulting solid particles. 'Cleaning' KL media is normally performed by backwashing the media at the appropriate frequency and backwash rate for the appropriate duration.Just have to figure out how to clean my Fe filter now.
Thank you for that explanation.The Backwash cycle will cause the media to be lifted and loosened so as to elimnate solidified (Ferric) iron particles to drain that were trapped in between the media granules. If the drain flow rate is insufficient, then media expansion will be less than optimal and so some ferric particles may remain trapped within the media bed.
Backwash also will cause the media to circulate (reclassify) within the tank. As water will eventually carve pathways (channels) through the media, and because water will always follow the path of least resistance, the media along those paths will become over saturated and therefore the filter will become less effective. Reclassification will eliminate those channels which will improve media effectiveness as the water will need to follow new routes through the media following each backwash cycle.
Because the spaces between media granules will be expanded in loose media, this will provide a shortcut for unfiltered water to flow through the media. The main purpose of the Rapid Rinse cycle is to recompact the media bed to eliminate those shortcuts to increase water contact with the media. Rapid Rinse will also elimnate unfiltered water from the tank which entered during the backwash cycle.
Part of the job of KL media is to first oxidize Ferrous iron so the resulting solid Ferric particles can be removed by the remaining media below. If the tank diameter is too small for the flow rate or quantity of ferrous iron, then oxidation may occur too far down within the media bed, thereby leaving insufficient media below to effectively remove the solid ferric particles. Chlorine, Hydrogen Peroxide and Ozone are all oxidizers that are often utilized individually to boost the oxidation capability of the KL media
The 600 opposite the F means 6 gpm. That is less than optimum for KL.My KL tank is 10"x54"
This is the button that came from the drain line.
