Iminaquagmire
DIY Senior Member
- Messages
- 206
- Reaction score
- 0
- Points
- 0
I'm replacing a corroded copper drain line in my crawlspace that services the kitchen sink up above. Currently, the AC, humidifier, and water softener all connect together and drain into a hole somebody drilled into the kitchen sink drain in the crawlspace. The drain hose is just siliconed into the hole and leaks, not to mention the sewer gas that comes back up through the hose.
What I'd like to do is re run separate drain hoses for each, then attach them properly to the drain in the crawlspace with a trap. But I'm not sure of the best way to do that. The only ways I can think of are to 1) simply run the hoses into a trap and secure them and 2) have three separate traps bushed down with hose fittings.
Which if either of the options should I do? Is there another option I'm not thinking of?
