Spencer Valeri
Hi all, I am planning to install a new water softener at my house. The home has never had one before so I will be installing from scratch. I recently picked up a GE 30,000 grain unit from Home Depot. The unit will be installed in my garage after the pressure tank but before the water heater. I have two drain options. There is a floor drain about 20 feet from the softener in the middle of the garage. The biggest problem I see with it is that the line would run into the middle of the garage leaving it susceptible to be driven over. Also I would need to find an air gap option which would leave a block or pipe in the middle of the floor to be stepped on or kicked. My other option would be to run a drain hose to my ceiling (7’3”) and across the garage into the laundry room (about a 36 foot horizontal run). The manual for this GE softener says to avoid runs longer than 30 feet and higher than 8 feet. So do you think that option would work with this softener or would I be able to do it with a different unit like this one Fleck 5600SXT 48,000 Grain Water Softener Digital SXT Metered Whole House System https://www.amazon.com/dp/B00OGN3162/ref=cm_sw_r_cp_api_x2.rAb02F0DHV
Thanks in advance for all your help.
