Snake Twisted and stuck in the pipe
Tong
Los Angeles, CA
Might have done something stupid. When I insert snake into a clog pipe, I probably have put a little more pressure on it. Now the snake is twisted and stuck in the pipe. Used a brutal force to move it. Did not work. The snake is now stretched thin.
What should I do next? How much to replace a pipe. Will take a picture and post it tomorrow.
Tong
Los Angeles, CA
Well. Believe it or not, after almost 4 months, the issue is resolved.
What I did.
1. add dish detergent into the pipe occasionally
2. to pull and push the cable almost daily to see if the torque tension can be released.
After a while, the cable became loose. I was finally able to pull it out.
My guess is that the temperature difference between daytime and nighttime can help release some tension gradually.
Furthermore, LA has a cold winter this year. Once the cable shrink a little, it could help to release the tension as well.
Anyway, my point is that be patient. It may take a while.
Sylvan
Still learning
New York
Normally when snaking a line it is good practice to use detergent for the following reasons
1- It acts as a lubricant
2- It cleans the cable
Tong
Los Angeles, CA
Yeah. Use a better drain snake. Thanks for all of the responses.
Ground temperature does change with time. However, it has different time delay with respect to ground temperature. Depending upon the depth below the ground, it has time delay of 12 hours, diurnal variation (24 hours), seasonal variation and annual variation. For pluming practice, it is usually 0~5 meters below the ground. So, It has a seasonal variation.
