Snake Twisted and stuck in the pipe
Discussion in 'Drain Cleaning' started by Tong, Nov 22, 2018.
  1. Tong
    Tong New Member
    Mar 16, 2018
    Los Angeles, CA
    Might have done something stupid. When I insert snake into a clog pipe, I probably have put a little more pressure on it. Now the snake is twisted and stuck in the pipe. Used a brutal force to move it. Did not work. The snake is now stretched thin.
    What should I do next? How much to replace a pipe. Will take a picture and post it tomorrow.
  2. Tong
    Tong New Member
    Mar 16, 2018
    Los Angeles, CA
    Well. Believe it or not, after almost 4 months, the issue is resolved.
    What I did.
    1. add dish detergent into the pipe occasionally
    2. to pull and push the cable almost daily to see if the torque tension can be released.
    After a while, the cable became loose. I was finally able to pull it out.
    My guess is that the temperature difference between daytime and nighttime can help release some tension gradually.
    Furthermore, LA has a cold winter this year. Once the cable shrink a little, it could help to release the tension as well.
    Anyway, my point is that be patient. It may take a while.
    Reach4 likes this.
    Reach4 likes this.
  4. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing- - fire suppression
    New York
    Normally when snaking a line it is good practice to use detergent for the following reasons
    1- It acts as a lubricant
    2- It cleans the cable
Similar Threads: Snake Twisted
Drain Cleaning Kinetic Water Ram vs. Milwaukee AirSnake Feb 22, 2019
Drain Cleaning Snake works, but clogs soon after Aug 12, 2018
Drain Cleaning Clog - snake doesn't work & out of ideas Jun 17, 2018
Drain Cleaning What do you all think of the consumer small snakes? Apr 4, 2018
Drain Cleaning Irrigation drain-safe to use cutter blade/snake in? Sep 21, 2017
