ltlistener
As part of a bathroom remodel we moved our toilet about 3 inches (45 degrees from previous placement), which has made the bathroom much more functional. However, the shower drain now stinks.. bad (its upstream of the toilet). When you flush the level of the p trap water in the shower goes up and then back down...
The toilet flange goes directly into a 3" sanitary tee... then runs through two 3" 22 degree fittings to move the few inches to get back to the 3 inch stack out... is this a venting issue or are the 22 degree fittings causing backflow due to flush volumes?
Any ideas on potentially helping the situation?
