William Cooley
Goal is develop smart hot water recirculation system as off-the-shelf products don't meet my needs.
I have two water supply zones. The whole house is on 3/4" except master bathroom shower and jacuzzi tub on 1". Zone are separated just downstream of water heater.. I want to recirculate the 1" zone.
The jacuzzi tub enclosure already has power and plenty of room to add equipment.
I have two ideas:
1) A pump that sits in the jacuzzi enclosure and pumps hot water into cold side. Would be controlled with smart switch (easy). Would need a mechanical, normally-closed valve to shut off crosslink.
2) A wifi-enabled valve to crosslink the hot and cold at the jacuzzi. The pump would be located on the hot water heater (traditional). Smart switches would open the crosslink and then run the pump for a set time.
Any leads on a wifi valve or pump with built-in stop valve? Commercial products are all 3/4".
Open to alternative ideas, too.
I have two ideas:
