small river pump loosing a little prime?
ushere
rural nsw, australia
hi,
we have a small pumpmaster installed next to the 'river':
View attachment 108039]
the lift from the river is about 7mt.
it's been working well for a couple of years, but has recently been loosing prime. it's supposed to be self priming, but as show in next pic. it has a pressure switch on it. if i top up through the pump screw plug on top, it takes maybe 1/4 to 1/2 lt, and then goes well thereafter.
i have a couple of questions, though would also appreciate any other observations that readers care to make:
a. would removing the pressure switch (we can turn it off and on from the house when necessary), force itself to prime automatically when turned on?
b. would installing a manual cut-off valve on the output stop any drainage?
of course, i'm open to any thoughts you might have ;-)
tia leslie
Shaft seal could be leaking air not water. Is there a check valve/ foot valve at end of suction pipe? Pump stops pumping after so much time?
Since the system is equipped with a pressure switch, is there also a pressure tank installed? A pressure tank will store a volume of water under pressure, even while the pump is not operating. Opening a faucet will then result in water flow, but once the water pressure becomes reduced to the pressure switch cut-in setting, the pump will then be reactivated
An always pressurized system will reduce the potential for both air to leak in and loss of prime. A pressurized system will also assist to recognize when there is a leak since the pump will become repeatedly activated even when there has been no water use.
Your system should be equipped with a Foot valve in the river. A Footvalve is an intake screen which is equipped with a check valve (one way valve), that opens to allow water to enter while there is suction in the suction line, but then closes fully to prevent water from draining out when the pump is shut off. The footvalve should be the only check valve in the system, as that will ensure the suction line will be pressurized by the pressure tank while the pump is not operating.
