Grant McAllister
I hope someone can help. I have been trying to find the solution to my problem for over a year now. House was built in 2007. It is city water. The plumbing is PEX. The hot water heater is gas and has about a foot of copper piping coming in and going out of water heater. My issue: I recently bought this home and after I moved in I immediately noticed small black particles coming out of my water faucets and tub and shower. The spots are usually small, black, and often smear like grease. Often the spots can be more solid and kind of dissolve into brownish smear when rubbed together. I had my water tested (came back OK), I replaced the line from city water to my home with new copper line. It didn't fix problem. I called city and they tested water and found some of these black spots on their end and they replaced copper line to my house. I have also had a filter installed, which still occasionally catches small black spots. Now my cold water mostly runs clear, but not always. I also discovered that the expansion tank on my water heater was full of a greasy like substance. I had the copper pipe replaced and the expansion tank. The piping connecting to the expansion tank had some kind of corrosive buildup that was brownish and black, kind of slimy. That's why I had the whole pipe replaced. So, now the biggest problem occurs when I run hot water from the tub. There are always black particles. Often when I run the sink faucets, I see the black spots as well, mostly on hot end, but definitely with cold, too. If I go out of town the problem is really bad. In fact, for the first few seconds, I get what looks like rust coming out when running hot. It then runs clear, but has several small black spots until I run my hot water for at least 5 minutes. So, my question is: does anyone know what is going on? I have no rubber in my lines that I can find and the plumber have no idea where any rubber could be. City insists that their end now runs clear, which it does. I can't explain how in my house the cold doesn't always run clear. Is my water heater bad and full of this gunk and somehow contaminating the cold, too? Or worse...do I need to replace all of my piping? Are my pipes full of these spots? I am at the end of my wits. I hope someone has some suggestions.
