Our toilet was having various issues so I decided to just replace everything. I got a fluidmaster kit (not the dual flush) and installed it. I waited a day and felt around under the tank and could feel a little water. There was clearly a slow leak. I'm not sure the brand of the toilet, but it is set up so when you tighten the tank to the base, it has ceramic ridges so you can't make the seal very tight before it bottoms out. I felt like I would have preferred to squeeze the seal a bit more but couldn't because of this "feature".
My real question is this: I pulled the tank off, set it on the sink and filled it with water. It leaks like a sieve around the main valve (the one with the flapper). Should the tank hold water when not mounted to the base? It seems to me that it should, and that the big seal between the tank and base should only come into play during the flush. Is that right? If so, any idea what I could have done so wrong? There's a big rubber gasket on the main flapper valve that I think should be holding water.
Thanks.
Thanks.
