UStralian
I've got two septic tanks, one of which only services the kitchen and basement laundry, in the configuration shown in the attached image. The kitchen sink drains directly to the septic, the washer drains to the laundry tub, which has a pump under it to lift water to the septic drain. Every time the pump turns on, the water backs all the way up to the kitchen sink, coming out the drain and the autovent under the sink.
First thought was that the tank needed pumping, but we had that done, and the problem is still there. Second thought was that the pipe out to the septic must be blocked, but I've snaked it thoroughly with a drill driven auger with a big head on it, and dropped some draino gel down there for good measure. There's a ball valve on the pump outlet to control flow, it's set as close to closed as i can make it. We can get a load of laundry done (it just gurgles a bit), but if i run the faucet straight into the tub, it backs up pretty quickly.
Any suggestions on what i should try or check next?
