Infinitysa
I bought an inexpensive linear drain online that has the drain outlet at one end. The trough of the drain has a very very slight slope, such that when perfectly level, a small amount of water remains in the trough through surface tension.
Since the outlet is 1.5 inches from one end, I could install the drain sloped toward the outlet. Would this be a good idea? It will still hold water in the small space past the drain outlet, but the majority will drain better. Some experimenting shows that about 1/8” per foot helps quite a bit.
Manufacturers instructions just specify to level the drain, but they are pretty basic, so I am wondering if anyone has an opinion on the matter.
Thanks.
Thanks.
