I have the flushmate 101526. This is the older model with the 'beer keg' shaped stainless tank. It has been a great toilet for about 15 years. Recently I've had a problem with the T fitting on the top of the tank ('upper supply group) leaking...sometimes spurting a stream out.
after flushing. I think a new rubber check valve will fix this. The other problem is after hearing strange noises, I observed the china tank was filled almost to the top! It appears the drain extension on the bottom is clogged. Can this be cleaned, or is replacement the only option?
(we have a lot of minerals in our well water here)
Thanks,
Scott
Thanks,
Scott
