So I've recently renovated the bathroom. Including new steel tub, pluming, drains, floor, walls, etc. Now I'm trying to hook up the drain before going any further. I bought a standard pvc kit with a trip lever.
My problem is that when I connect the drain shoe to the t-connector via slip joint - it keeps leaking. I've tried it 3 seperate times.
1st time - 3 times around with teflon tape and twisted it hard as I could by hand.
2nd time - 4-5 times around
3rd time 5-6 times around w/ teflon tape and pipedope and pieced together before putting under tub (because its hard to tighten once its in there) twisted as tight as I could go. Even put the wrench on it.
The 3rd time it leaked less however there is still a leak. I'm wondering show I not use the teflon tape and just use the pvc fittings and wrench them as tight as possible?
Or should I move on to a brass piece system where you don't have the slip joint.
