WTunick
Tried to read up as much as I could on this site about my question (and have learned a lot), but have a particular set of circumstances and thought I might post them to see if anyone had any advice.
My question is basically what size pipe should I use in replacing galvanized water lines in our house.
By way of background, the house was built in the 50's, only two bathrooms over a crawl space. Moved in two years ago and upgraded the services from the meter to 1" copper (have about 70 psi coming in from the street). Also one of the bathrooms is already plumbed in copper (3/4" line with 1/2" to all the fixtures). We are currently remodeling the other bathroom and since it is back-to-back with the kitchen, thought it would be a good time to replace the old pipes. I am relatively handy and have soldered copper before, but the idea of soldering copper under the house did not appeal to me so decided that I would use either CPVC or PEX in the crawl space and use copper where the supply enters the house and in the walls. In any event decided to go with CPVC since I had never worked with PEX and did the replacement last weekend.
Now I have 1" copper from the meter to 1" CPVC which splits to into two 3/4" CPVC lines. One goes to the hot water heater, transitioning to 3/4" copper on the way, and the other goes on to feed the rest of the house. The hot water comes out of the water heater as 3/4" copper and then transitions to 3/4" CPVC to feed the rest of the house. Each fixture is fed by a 1/2" CPVC line coming off the 3/4" feeds.
Now that I have all the CPVC in place, it seems that the flow throughout the house (both hot and cold) is less than it was before I replaced the galvanized pipes (which were 3/4" for the most part and only partially corroded). Got me thinking that I should have paid more attention to the I.D. of CPVC and maybe upsized all of the CPVC to 1" with 3/4" feeding the fixtures or gone with PEX and done the same thing.
Anyway, my question at this point is would I see a noticeable difference in flow if I changed out all the 3/4" and 1/2" CPVC for 1" and 3/4" CPVC or PEX, so that the system would be entirely 1" or 3/4" Copper and CPVC/PEX. It isn't that much work or money to make the change, but if it isn't going to make much of a difference I won't bother.
Figured there is so much experience on these forums that someone might have a little insight.
Thanks,
William
Thanks,
William
