WalterJ
Sink is on Peninsula and 5 feet from vent stack in wall to roof.
Before Conversion: 2 Basin Stainless Kitchen Sink, 2" PVC Exit Drain, to 2" PVC P-Trap, to PVC Adapter 2" to 1 1/2" Kitchen, to 1 1/2" Kitchen Adjustable T and Fittings, 1 Side Disposal = Drains Perfect.
After Conversion: 1 Basin Porcelain Kitchen Sink with Disposal
Attempt 1 = no under-cabinet vertical pipe without Air Admittance Valve,
same 2" PVC Exit Drain, to same 2" PVC P-Trap, to same PVC Adapter 2" to 1 1/2" Kitchen, to NEW 1 1/2" Kitchen Elbow and Fittings, to Disposal = NO GOOD. Backs up after 2 minutes, takes 1 hour to dissipate.
Attempt 2 = YES under-cabinet vertical pipe WITH Air Admittance Valve (Oatey Sure-Vent, Studor Mini-Vent),
same 2" PVC Exit Drain, to same 2" PVC P-Trap, to same PVC Adapter 2" to 1 1/2" Kitchen, to SAME 1 1/2" Kitchen Adjustable T and Fittings, to Disposal and vent pipe = NO GOOD. Backs up after 2 minutes, takes 1 hour to dissipate.
What is the problem? Worked fine with 2 basins.
Called professional plumber for consultation. Said Vent Stack in wall 5 feet from drain is good and within code, no need for dangerous Air Admittance Valve. Recommended reduce to 1 1/2" Kitchen P-Trap, claiming problem was 2" PVC P-Trap was too large. Why? Hard to believe. 2" P-Trap Worked fine with 2 basins.
(yes, snaked both drain and cleanout just to be sure)
