Verdeboy
- Messages
- 2,041
- Reaction score
- 6
- Points
- 0
Mary B said:Hmm? A mixing valve with a self closing metered faucet would give the user warm water when they pressed BOTH the hot and cold water tap? I was under the impression that you could still get cold water when you pressed the cold handle and warm (not HOT) when you press the hot handle. No?
The last posting stated that you get luke warm water in both the hot and cold faucet when using a point of service mixing valve under the sink.
I just threw that out there as a possibility. So you wouldn't have extremes of either hot or cold. You could certainly have a separate supply of cold water to the cold water tap and a mixture of hot and cold to the hot. The easiest thing, however, would be to just have one push-down metered knob with tempered water. It's not like trying to work a standard single lever faucet that swivels and pulls out. You just walk up to it, push it down, and do your business.
