Adam Smith
Hi Everyone!
New to the forum. I spent my college years and a few years after in construction. Mainly remodels and have had the privilege of doing most aspects of construction. I bought a house last summer with an unfinished basement that the previous homeowner did partial work on. Most of what they did I've had to tweak to get it up to code and I'm seeing what looks like another area I will need to fix.
The existing homeowner wanted to change the builders rough in from a single to a double vanity which I will do as well. It looks like they were going to just extend the original drain pipe and add the second sink but that will pull the water out of the p trap closest to the main stack if I'm not mistaken.
I looked through the site and have no problem understanding how to convert the single to a double in most cases, but at the base of my stack I have the clean out which prohibits me from tieing in below where the original plumber connected the vanity waste, and I'm afraid if I tie in above, I will be too high once I drop the sink in. The sink waste pipe is 22" above the floor. How high is too high for a second pipe?
Can I pull from the vent stack to the left and tie into the far right sink? Or can two sinks not share one waste pipe even if the furthest sink from the stack has a vent? See attached pics with red indicating the proposed vent.
I also attached a pic I found on the site that is the closes scenario to mine expect they don't have a clean out where the two sinks meet the vertical pipe. As mentioned above, I can just tie in above the original plumbers, I'm just not sure how high I can go before I start running into issues with the sink.
