Simple help with proper connection
Vungu
Akron, OH
Hi, running a new plumbing line for kitchen sink. Please help with proper fitting. Will be 1 1/2" pipes. I labeled the connections as 1,2, and 3. It's a long horizontal run to the drain. Hope my drawing is clear enough.
Vungu
Akron, OH
Thank you HJ. Now just to confirm, the long 24' run I have to drop it by 6", and the 8' run drop another 2". Is that right?
At connection #3, can I run from the sink to the vent. Use a sanitary T, and then below the sanitary. Run a sweeping 90 to connect to the horizontal? Thanks again.
Ladiesman217
MA
Does drilling holes in every stud for 32 feet violate any building codes?
What size are the wall studs? Are they load bearing? Are they located on exterior walls?
