Silicone and gasket for Leaky tub drain?
Baltik
SF
So my recently installed (not by me) tub is starting to leak at the drain. I wanted to take the opportunity to replace the drain at this juncture anyway. The new drain comes with 2 rubber gaskets (and no instructions) should I just use the gaskets or is advisable to use putty/silicone as well?
I would try the supplied gaskets first.
Once you add Silicone to that, it's hard to go back. What tub do you have that is has a drain like that?
