Peter Lifrieri
Hello:
I have an 11 year old refrigerator connected to a dedicated shut off valve. I basically never use the water or ice maker and since the line (white plastic type) is also 11 years old, I'm considering shutting the valve (I don't know when I will get around to replacing the plastic supply line.) My question is, if the valve is shutoff let's say for 2 years, could it cause any damage to the general plumbing system (copper)? Will the valve have a greater chance of failing if in the closed position for an extended period of time? Just want to know if it's okay to shut down as a preventative measure since I hear plastic supply lines for refrigerators like to fail at around 10 years.
Thank you,
Pete
Thank you,
Pete
