Ameli0rate
To elaborate - does it make sense to set the water heater to a temperature where I can shower with the handle to full-hot, or should the water heater be set to a higher temp and I mix hot and cold in the shower?
Does energy savings figure in? If I mix my hot water with cold, I use less water heater water, but I have to heat it more to mix it with cold to get it comfortable.
If I turn it down, I use more water out of the water heater, so it drains faster and has to reheat more water..?
Do flow rates matter here?
