stacyburket
Ok, installed a new shower panel (in house #1). Valve will not mix hot and cold. It's either all hot or all cold.
I gradually turn from one temp to the other and temp suddenly changes to the other extreme.
Swapped entire panel with another panel I know to work fine (taken from house #2).
Same exact problem with this panel which was just working fine in other house.
I took this panel back to house #2. It again,works fine.
Just for kicks I took another brand new shower panel out of the box and connected in house#1.
Same problem. Valve will not hold a medium temp. Only extreme hot or extreme cold.
I'm forced to believe its something in the house.......??
I'm on a regular water heater (not tankless)
Old existing shower temp with old valve was fine before all this.
pressure (both hot and cold) is and was always fine.
Baffled, please help
Stacy
Stacy
